Where is the sarcasm smiley... :confused:
Guess my dmx with a stock cover isn't "super big bore" enough.
Unless your motor is kicking back on you hard enough to kill covers, a stocker is fine, and even then. There are ways to prime your motor so it is less likely to kick back on you.
:-D
so your telling me the only way the cover will break is if the motor kicks back?
wtf so much so usless info(from other post not from you)
Not sure what post you are referring to, but yes. When a motor kicks back it puts reverse pressure on the kicker gear and puts a tremendous load on the cover. It can (and will) also break teeth off the kickstart idler gear, as well as breaking the teeth or shattering the gear on the backside of your clutch basket.
