KarTek Posted January 30, 2012 Report Posted January 30, 2012 I was looking at the frame today and I just noticed that the lower tubes are not even and straight. The right tube runs forward and inward toward the center line then takes a turn to run straight forward. The left tube simply runs forward at an angle to the area where the tubes join. Is this normal or did mine take some sort of hit? Thanks! Quote
KarTek Posted January 30, 2012 Author Report Posted January 30, 2012 OK great, thanks. Today was the first time I had gotten down under the front and given it a good look. Quote
locogato11283 Posted January 31, 2012 Report Posted January 31, 2012 It's normal, but it definitely looks like something is jacked up when you look at them from the bottom. Quote
