I wasnt trying to be sarcastic at all. I apologise if it came off like that. If i was a genious with quads i wouldnt be on here asking for help.
Just trying to cover ALL posibilities, wouldn't be first time it happened, won't be the last. bangheadbangheadbanghead
If you're so fucking good with quads, why are you asking for help?? :jesterlaugh::jesterlaugh::jesterlaugh:
:jesterlaugh::jesterlaugh::jesterlaugh::jesterlaugh::jesterlaugh::jesterlaugh::jesterlaugh::jesterlaugh::jesterlaugh:
I took the parking brake off. I didnt realise there were so many little things that can cause such big problems. thank you guys. thats why i joined here, i figured this is where the most knowledge would be.
parking brake still on the bike? if so that could be the problem. if not you probably have a dirty pilot. as far as the slides go, there are little balls on the side of each slide make sure they are facing the right side of the carbs (if your looking at the bike from the back) there are little bubble windows on the carbs thats what they are for, then just set them from there. hope this helps
So can we assume it was the parking brake sensor? I had the same issue a few bikes ago. I worked on that damn thing for a week. banghead
Finally unpluged that damn sensor and it was good to go. :dance:
ya lol my brothers shee was out of commission for a couple days because the pb. we went over eveeeeerrrything couldnt figure it out then finally we were just frigin with the pb then decided to try it an it worked fine after banghead stupid things should not be on there
I unhooked the parking brake and all tores before trying to start it. If its possible I think the groove on the slide is facing the left side. So is it possible I have the carbs on the wrong sides. I'm not 100% sure but think it faces the left. I didn't think I could put them on opposite sides and still hook up the crossover tube. I will double check all this tomorrow night. What size main jet sounds right for this once the toomey t-5 pipes show up
