D_illmam Posted January 16, 2012 Report Share Posted January 16, 2012 Hi guys and gals I have a 2002 Banshee that has been rebuil. The bottom end is from a total different banshee that was bought from a wrecker but the jugs and top end are the original. I am having problems with piston to head Clearence. I have tried three different pistons but the only way I can make it clear is to have 3 head gaskets in. The original head is not milled or shaved. Any help would be greatly appreciated 1 Quote Link to comment Share on other sites More sharing options...
Phelps Posted January 16, 2012 Report Share Posted January 16, 2012 wrong base gasket thickness, or it's a 4mil crank Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted January 16, 2012 Report Share Posted January 16, 2012 what piston to head clearance are you coming up with? and how are you measuring it Quote Link to comment Share on other sites More sharing options...
D_illmam Posted January 16, 2012 Author Report Share Posted January 16, 2012 wrong base gasket thickness, or it's a 4mil crank Thanks for the quick response, How would I kmow if it's the 4 mil? I am going to get the vin of the bottem end this week as the guy isn't exact sure what year it was from. Was there much different in the years of production? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted January 16, 2012 Report Share Posted January 16, 2012 That number won't tell you jack. How far is the piston sticking out of the jug? Bet Phelps is right. Quote Link to comment Share on other sites More sharing options...
D_illmam Posted January 16, 2012 Author Report Share Posted January 16, 2012 what piston to head clearance are you coming up with? and how are you measuring it It has actually blew up twice, as soon as it warms up. I will ask the guy how he is measuring it. I am thinking it may have something to do with mix matching bottem and top ends from different years? It was a barn find and I can get it at a excellent deal just trying to figure this problem out. Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted January 16, 2012 Report Share Posted January 16, 2012 same engine for 10000 years. how far do the pistons stick out of the block ? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted January 16, 2012 Report Share Posted January 16, 2012 So do you actually own it, or going to get it if you can fix it? Quote Link to comment Share on other sites More sharing options...
D_illmam Posted January 16, 2012 Author Report Share Posted January 16, 2012 same engine for 10000 years. how far do the pistons stick out of the block ? I can get it checked this week. I can get it for 1000 canadian . On fresh rebuild but it has potential to blow again. Quote Link to comment Share on other sites More sharing options...
D_illmam Posted January 16, 2012 Author Report Share Posted January 16, 2012 So do you actually own it, or going to get it if you can fix it? It's a good friends who found it in a barn. He now has a job out of province and said he would sell it for 1000. Just trouble shooting before I pick it up Quote Link to comment Share on other sites More sharing options...
Phelps Posted January 16, 2012 Report Share Posted January 16, 2012 someone would have had to put the 4mil crank in if it has one. didn't come stock like that. only other way would be if you was not running a base gasket. check the stroke from top to bottom. find out if it's 54mm, or 58mm stroke. if it has a 4mil crank you wont be able to run stock jugs (well you will, just have less power than stock lol) and you will need a aftermarket head with 4mil domes. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted January 16, 2012 Report Share Posted January 16, 2012 If it's in reasonable condition otherwise and has some aftermarket things it might be an ok buy. I would try to talk him down, unless owner is a friend I'd lay a line of shit, some of which may be true. One other thought I had is it may have short rod pistons on long rods. Either way you will probably have to buy something after you figure it out. Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted January 16, 2012 Report Share Posted January 16, 2012 youd buy a running one for that. offer him 500$ even if it has no base gasket, which we will say is .020" and a stock head with stock stroke with squish at around .035 (at a tightest) you still have .015" of clearance with out a base gasket. need to know how far out those pistons protrude through the bore. Quote Link to comment Share on other sites More sharing options...
mikechief Posted January 16, 2012 Report Share Posted January 16, 2012 stock squish is pushin .080" you could shave .040" off the head forget the base gasket and probably still not have contact if you have base gaskets and3 head gaskets that's like 3mm ... Gota be 4mm maybe a 7 Quote Link to comment Share on other sites More sharing options...
