Hi guys and gals
I have a 2002 Banshee that has been rebuil. The bottom end is from a total different banshee that was bought from a wrecker but the jugs and top end are the original.
I am having problems with piston to head Clearence. I have tried three different pistons but the only way I can make it clear is to have 3 head gaskets in.
The original head is not milled or shaved.
Any help would be greatly appreciated
  • Like 1
wrong base gasket thickness, or it's a 4mil crank
Thanks for the quick response,
How would I kmow if it's the 4 mil? I am going to get the vin of the bottem end this week as the guy isn't exact sure what year it was from.
Was there much different in the years of production?
what piston to head clearance are you coming up with? and how are you measuring it
It has actually blew up twice, as soon as it warms up.
I will ask the guy how he is measuring it. I am thinking it may have something to do with mix matching bottem and top ends from different years?
It was a barn find and I can get it at a excellent deal just trying to figure this problem out.
same engine for 10000 years.
how far do the pistons stick out of the block ?
I can get it checked this week.
I can get it for 1000 canadian . On fresh rebuild but it has potential to blow again.
So do you actually own it, or going to get it if you can fix it? :confused:
It's a good friends who found it in a barn. He now has a job out of province and said he would sell it for 1000. Just trouble shooting before I pick it up
someone would have had to put the 4mil crank in if it has one. didn't come stock like that. only other way would be if you was not running a base gasket. check the stroke from top to bottom. find out if it's 54mm, or 58mm stroke. if it has a 4mil crank you wont be able to run stock jugs (well you will, just have less power than stock lol) and you will need a aftermarket head with 4mil domes.
If it's in reasonable condition otherwise and has some aftermarket things it might be an ok buy. I would try to talk him down, unless owner is a friend I'd lay a line of shit, some of which may be true. One other thought I had is it may have short rod pistons on long rods. Either way you will probably have to buy something after you figure it out. :cheers:
youd buy a running one for that. offer him 500$
even if it has no base gasket, which we will say is .020" and a stock head with stock stroke with squish at around .035 (at a tightest) you still have .015" of clearance with out a base gasket.
need to know how far out those pistons protrude through the bore.
stock squish is pushin .080" you could shave .040" off the head forget the base gasket and probably still not have contact
if you have base gaskets and3 head gaskets that's like 3mm ... Gota be 4mm maybe a 7
