I was given a durablue stock length hd axle for my banshee. I think i'm missing a part though because once installed, there is space between the sprocket hub and the sliding axle nut that goes over the circlip. or maybe the sliding axle nut goes against the sprocket hub and there should be a spacer between the nut and circlip. am I missing a spacer of some sort. I'm not sure what it looks like but maybe its the capture collar?
