bluebanshee98 Posted December 27, 2011 Report Posted December 27, 2011 i noticed and have been kind of thinking that my clutch plates/friction discs are prob on the way out. i def noticed it yesterday when i was on the street just kinda cruising in 6th gear and kinda did a roll on.. it started to rev high, then reved down a lil then back up ( with wot the whole time) and then the acclration really started kicking in. it doesnt seem too bad in first and 2nd. so the plates are prob shot right? also today i was riding and now it seems to be stuck in 2nd and will only shift up 3rd. it will only shift down to 2nd. did a lil research on this site and it seems that the shift fork is bound up or maybe the gears seized on the shaft. fluid is good and full. thoughts everyone on both subjects?? down the road at some point i may go 4 mill to double the hp. i can never seem to get enough so if i get new plates and dics its prob gonna be the ones with the r1 plates in them. Quote
Nieskes Posted December 27, 2011 Report Posted December 27, 2011 Take it apart and look I guess, sounds like its time for a new clutch. Quote
dcalsv02 Posted December 27, 2011 Report Posted December 27, 2011 Check your clutch adjuster also....probably wouldnt be a bad idea to just go through it all to be sure. Quote
bluebanshee98 Posted December 27, 2011 Author Report Posted December 27, 2011 Check your clutch adjuster also....probably wouldnt be a bad idea to just go through it all to be sure. i looked at the engine where the clutch cable goes to and made sure the 2 pointy arrows where horizontal with each other. does that make sence? Quote
sheerider11 Posted December 27, 2011 Report Posted December 27, 2011 Those arrows don't mean anything. That's just a reference point you can adjust it with out lining those up. Just pull the cover off and see how the fibers and steels look. I got a tusk clutch for super cheap with the HD springs and used 3 of them and 3 stock. Clutch feels awesome. Quote
bluebanshee98 Posted December 27, 2011 Author Report Posted December 27, 2011 (edited) Those arrows don't mean anything. That's just a reference point you can adjust it with out lining those up. Just pull the cover off and see how the fibers and steels look. I got a tusk clutch for super cheap with the HD springs and used 3 of them and 3 stock. Clutch feels awesome. i was just looking on ebay at the tusk kits. i do plan to double the h.p. of the bike over time (70-85ish hp.) will that clutch kit be fine even with the increase of h.p? i was thinking of getting this..... http://www.ebay.com/itm/Tusk-Clutch-Kit-w-HD-Spr-Yamaha-Banshee-350-87-06-/250958365149?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item3a6e48c1dd Edited December 27, 2011 by bluebanshee98 Quote
sheerider11 Posted December 27, 2011 Report Posted December 27, 2011 That's the one I use I think. Mine came from Rocky mountain. I have a 4 mil and a hjr port. I have no problems. I use atf type f. No slipping and catches awesome Quote
bluebanshee98 Posted December 27, 2011 Author Report Posted December 27, 2011 That's the one I use I think. Mine came from Rocky mountain. I have a 4 mil and a hjr port. I have no problems. I use atf type f. No slipping and catches awesome whats atf type f mean? lol sorry i might be shot right now Quote
sheerider11 Posted December 27, 2011 Report Posted December 27, 2011 Automatic tans fluid. That clutch is almost like an automatic tans clutch pack. Quote
bluebanshee98 Posted December 27, 2011 Author Report Posted December 27, 2011 Automatic tans fluid. That clutch is almost like an automatic tans clutch pack. would it be bad or not a good idea to run that clutch kit and pro honda 80/85w ? i usually always used that in all my 2 strokes that i had http://www.rockymountainatvmc.com/productDetail.do;jsessionid=9693E8DBA4112A020AF886DC4926F01A?webCatId=23&webTypeId=398&navTitle=Chemicals&navType=type&prodFamilyId=11719&stockId=99096 Quote
sheerider11 Posted December 27, 2011 Report Posted December 27, 2011 I don't see why not. As long as it's2 stroke trans fluid you should be fine. But if you ask any one here you'll get all different answers of what's the best. I'm a tech at a Ford dealer so I get Ford atf for free, and I've never had a problem with it. Some people like yamalube. But I can say I've heard allot of good stuff about klotz. Quote
RadarRacing Posted December 27, 2011 Report Posted December 27, 2011 Bikes wont shift worth a darn of the clutch is out. It may not be forks or anything. That tusk kit is fine and is under $50. Quote
bluebanshee98 Posted December 28, 2011 Author Report Posted December 28, 2011 Bikes wont shift worth a darn of the clutch is out. It may not be forks or anything. That tusk kit is fine and is under $50. i ordered the kit. i def needed it. even if the old plates are shot i dont understand whats holding it up from shifting down or up? its in 2nd gear and will only shift to 3rd or back down to 2nd. when i click it up to 3rd for a example when i roll it a lil the lever moves up or down from its original spot. i remember when my old 89 cr250r needed new clutch plates/dics i was still able to shift but when i put it in gear it wouldnt go anywhere it would just rev out and barely move at all. something has to be held up..???? Quote
sheerider11 Posted December 28, 2011 Report Posted December 28, 2011 i ordered the kit. i def needed it. even if the old plates are shot i dont understand whats holding it up from shifting down or up? its in 2nd gear and will only shift to 3rd or back down to 2nd. when i click it up to 3rd for a example when i roll it a lil the lever moves up or down from its original spot. i remember when my old 89 cr250r needed new clutch plates/dics i was still able to shift but when i put it in gear it wouldnt go anywhere it would just rev out and barely move at all. something has to be held up..???? can you go through the gears when the bike is off? because if its running then it might be to much load on the trans. if you cant shift with the bike off and just rocking it back and forth then you have a problem. Quote
bluebanshee98 Posted December 28, 2011 Author Report Posted December 28, 2011 (edited) can you go through the gears when the bike is off? because if its running then it might be to much load on the trans. if you cant shift with the bike off and just rocking it back and forth then you have a problem. great..... yea it wont shift up or down more then ONCE when its running or when the bike is off rocking it back and forth..... what do you think the problem is? i took the clutch cover off to see if i can see anyrthing..... i dont have a clue to be honest. to the stealership is where it might have to go its gonna be a pain in the @ss to get it in the back of my truck too because i cant get it into neutral its stuck in 2 and 3rd. Edited December 28, 2011 by bluebanshee98 Quote
