bansheerilla Posted December 14, 2011 Report Share Posted December 14, 2011 Can't figure out why I have coolant coming out where the headermeets the cylinder? Quote Link to comment Share on other sites More sharing options...
SNTBANSHEE Posted December 14, 2011 Report Share Posted December 14, 2011 If your talking about the exhaust port then its probably time for a new head gasket. Does it put out alot of white smoke? Quote Link to comment Share on other sites More sharing options...
Finch Posted December 14, 2011 Report Share Posted December 14, 2011 Can't figure out why I have coolant coming out where the headermeets the cylinder? New gasket time Quote Link to comment Share on other sites More sharing options...
Infamous039 Posted December 14, 2011 Report Share Posted December 14, 2011 Yes new gasket and also check to make sure there is no damage to the head. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted December 14, 2011 Report Share Posted December 14, 2011 okay....that could be how to fix the part. But the real question is why did the problem start. Did you do anything to your bike recently like pulling the head off or did you change anything or run it out of fuel? any recent motor mods? Quote Link to comment Share on other sites More sharing options...
bansheerilla Posted December 14, 2011 Author Report Share Posted December 14, 2011 Sorry guys didt give any info....fresh rebuild with dune port job with cool head,timing plate adj,34 carbs,t5exhaust. Quote Link to comment Share on other sites More sharing options...
bansheerilla Posted December 14, 2011 Author Report Share Posted December 14, 2011 Just took off head and orings under domes look just a little flat on one side but not really, not sure if I'm going in the right direction. Quote Link to comment Share on other sites More sharing options...
Finch Posted December 15, 2011 Report Share Posted December 15, 2011 Just took off head and orings under domes look just a little flat on one side but not really, not sure if I'm going in the right direction. ya even if theres a lil pinch in those o rings theyll leak Quote Link to comment Share on other sites More sharing options...
bansheerilla Posted December 15, 2011 Author Report Share Posted December 15, 2011 thanks will change orings and see. good looking out. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 15, 2011 Report Share Posted December 15, 2011 just to clarify, it's actually coming out of the exhaust port? or is it coming from the bottom of the cylinfers, between the clyinders, or somewhere else? it helps to use a mirror, and check to see exactly where it comes out. could be the coolant line that drops off the head to the clutch cover, or could be coming from a bolt hole, or could have left out the plugs that go in the bottom of the cylinders, or, if you put a head gasket in there, then take it out. Quote Link to comment Share on other sites More sharing options...
