cobra_steven Posted December 2, 2011 Report Posted December 2, 2011 Well I have this knocking type noise...it's obviously coming from the bottom end...I've tried to do my research but the only thing that caught my eye is the idle gear...seems excessive but not too sure...trying to figure out without pulling off the basket...the clutch cover is already off. I can wiggle the idle gear pretty well...is it pose to be straight and wiggle free?? Quote
locogato11283 Posted December 2, 2011 Report Posted December 2, 2011 There should be NO play in the idler gear. Call FAST Racing and get the parts. 785-364-5325. You will need the bushing, washers and clip. To get the idler gear off, you will have to pull the clutch basket off. Quote
cobra_steven Posted December 2, 2011 Author Report Posted December 2, 2011 Ok thanks! As for the kick start gear...? It's very sloppy too!! I have a feeling it's the combination of the two makin the loud noise! Is that whole assembly gonna have to be replaced also? Quote
locogato11283 Posted December 2, 2011 Report Posted December 2, 2011 Ok thanks! As for the kick start gear...? It's very sloppy too!! I have a feeling it's the combination of the two makin the loud noise! Is that whole assembly gonna have to be replaced also? Are you talking about the actual kicker gear or the gear on the back of the clutch basket? Quote
cobra_steven Posted December 2, 2011 Author Report Posted December 2, 2011 The gear located on the kicker inside the case...also found something black crumbled up when I pulled off the white bushing and spring..I looked at a diagram.. Can't see any other bushing or o ring?? It was def brittle whatever it was a broke into a lot of pieces Quote
locogato11283 Posted December 2, 2011 Report Posted December 2, 2011 The gear located on the kicker inside the case...also found something black crumbled up when I pulled off the white bushing and spring..I looked at a diagram.. Can't see any other bushing or o ring?? It was def brittle whatever it was a broke into a lot of pieces Got any pictures? It's not the seal that goes in the side cover is it? There shouldn't be anything else on there. Quote
cobra_steven Posted December 2, 2011 Author Report Posted December 2, 2011 Not the seal... No pics... I have no idea what it is. Was inside spring/bushing area...pulled bushing/spring off shaft and was under there..?!? Quote
