cobra_steven
Everything posted by cobra_steven
  1. I agree...pretty good price!! Def a good buy...
  2. What's all included in the kit? For a banshee...
  3. What does shipping normally run?
  4. Bump for a clean ride....I'm in Tx too and these things are a blast to ride! Good luck w the sale..
  5. Yup.. All is good other than those 2 gears that wiggle like a loose tooth. Ordered new bushing and snap ring for the idle pully
  6. Not the seal... No pics... I have no idea what it is. Was inside spring/bushing area...pulled bushing/spring off shaft and was under there..?!?
  7. The gear located on the kicker inside the case...also found something black crumbled up when I pulled off the white bushing and spring..I looked at a diagram.. Can't see any other bushing or o ring?? It was def brittle whatever it was a broke into a lot of pieces
  8. Ok thanks! As for the kick start gear...? It's very sloppy too!! I have a feeling it's the combination of the two makin the loud noise! Is that whole assembly gonna have to be replaced also?
  9. Well I have this knocking type noise...it's obviously coming from the bottom end...I've tried to do my research but the only thing that caught my eye is the idle gear...seems excessive but not too sure...trying to figure out without pulling off the basket...the clutch cover is already off. I can wiggle the idle gear pretty well...is it pose to be straight and wiggle free??
  10. Well I have this knocking type noise...it's obviously coming from the bottom end...I've tried to do my research but the only thing that caught my eye is the idle gear...seems excessive but not too sure...trying to figure out without pulling off the basket...the clutch cover is already off. I can wiggle the idle gear pretty well...is it pose to be straight and wiggle free??
  11. I recommend giving it to whomever u are takin it to for the hone. I'm assuming u wanna hone the jugs before the new pistons. Have ur machine shop measure it for u...they will tell u the exact measurement and what piston kit to buy. They will have to fit each piston per jug either way. Good luck!
  12. Def gonna try to lean it out! Thanks
  13. Still working out a few issues on bike... Thinking I have a jet issue.... Lemme know what jets do u think I should be running... @ Sea Level 65.5 mm Wiesco 150 psi compression Stock carbs K&N Pod Filters Graydon Proline Exhaust Cool head w 20cc Advanced +4 What's in it now is 40/320 jets Bud tellin me I need to drop them to 30/300 What do y'all think!?
  14. Everyone just melt their Graydon and sell for scrap?
  15. When I bought my banshee, it had Graydon Proline exhaust...says so on the header pipes anyhow...rear mufflers don't say anything...just round cylinders basically......I hear they stopped making them a while back...?! That because they were sooo good which made them expensive? Ha jk....what kinda info can u guys tell me about this exhaust....should I just take them off n go with something else? Thanks!!
  16. Sweet deal...only if I had a need!! Want want want bump
  17. Sending payment now
  18. Will take chain and sprocket if still available
  19. What's the length of the chain?
  20. Pics of the cheaper set? And how much? Looking to cut and paint ...
  21. Plastics...race cut...or not... Color...full set or ....??
  22. Very interested. Still available?
  23. cobra_steven
    WTB
    2 K&N filters with or with pre filter....or a 2 into 1 with pre filter .... Or even just the pre filters without k&n....
