Looking for a couple opinions. I will not be able to rip the Banshee apart for a week, so I am looking for an opinion.
I was on my way back to the trailer this weekend and while riding in 2nd gear the Banshee quit putting power to the front sprocket. The motor still runs fine, and the transmission shifts fine, however no matter what gear she is in it will not turn the sprocket. Any ideas on what it could be before I rip it apart? I am guessing the gear that comes off the the output shaft came off or is loose.
Clutch is good. The oil is still clean. It is a FAST clutch with about 10 hours on it.
there is only 2 things that can be wrong with it.
clutch or a the gears between the crank and the sprocket are broken.
i am going with your clutch is fucked.
i call burnt clutch
