I have a set of 33MM PWK carbs and would like to get a starting point for jetting. You guys have helped me much in the past and I am pretty good at jetting my bike, but just want to get a baseline of where I should begin. Mods listed below.
Jets I currently have: Mains 150,152,155,158,160,162,165
Pilots 48,50,52,55
Elevation: Sea Level
Temperature : 75-65
Motor Mods:
Dune Port
33MM PWK Carbs w/ CGL Needles
Pod Filters
21CC Domes
VForce 2 Reeds
+4 Timing
T5 pipes
Stock Stroke Crank
93 Pump Fuel
OK guys I will start with 160 mains. I currently have 50 pilots in and its starting first kick everytime.
I have the same setup with 34 PJ's & mines dailed in with 52 pilots CEG needle mid clip 158 mains. Im in NC at sea level same temps as you.
The PJ jetting circuit is not the same as the PWK. They can't be cross referenced like you can between the PWK.
I am going to see how it runs with the 50 pilots first cause its starting up first kick, I will be able to test it out tomorrow after work and report back.
Do you have to choke it? If not, your pilot is too rich.
Yes I had to choke for the initial start up and I let run for about 5min or so then shut it down. Every start up after that was just one kick start.
