Infamous039 Posted October 11, 2011 Report Posted October 11, 2011 I have a set of 33MM PWK carbs and would like to get a starting point for jetting. You guys have helped me much in the past and I am pretty good at jetting my bike, but just want to get a baseline of where I should begin. Mods listed below. Jets I currently have: Mains 150,152,155,158,160,162,165 Pilots 48,50,52,55 Elevation: Sea Level Temperature : 75-65 Motor Mods: Dune Port 33MM PWK Carbs w/ CGL Needles Pod Filters 21CC Domes VForce 2 Reeds +4 Timing T5 pipes Stock Stroke Crank 93 Pump Fuel Quote
Badbar88 Posted October 11, 2011 Report Posted October 11, 2011 I have a pretty similer set up and I run 160's and 48's if I remember correctly. Quote
locogato11283 Posted October 11, 2011 Report Posted October 11, 2011 162 main. 48 pilot. Needle in the middle. Air screws 2 turns out. Quote
Infamous039 Posted October 11, 2011 Author Report Posted October 11, 2011 OK guys I will start with 160 mains. I currently have 50 pilots in and its starting first kick everytime. Quote
252wheelieking Posted October 12, 2011 Report Posted October 12, 2011 I have the same setup with 34 PJ's & mines dailed in with 52 pilots CEG needle mid clip 158 mains. Im in NC at sea level same temps as you. Quote
locogato11283 Posted October 12, 2011 Report Posted October 12, 2011 I have the same setup with 34 PJ's & mines dailed in with 52 pilots CEG needle mid clip 158 mains. Im in NC at sea level same temps as you. The PJ jetting circuit is not the same as the PWK. They can't be cross referenced like you can between the PWK. Quote
Infamous039 Posted October 12, 2011 Author Report Posted October 12, 2011 I am going to see how it runs with the 50 pilots first cause its starting up first kick, I will be able to test it out tomorrow after work and report back. Quote
locogato11283 Posted October 12, 2011 Report Posted October 12, 2011 I am going to see how it runs with the 50 pilots first cause its starting up first kick, I will be able to test it out tomorrow after work and report back. Do you have to choke it? If not, your pilot is too rich. Quote
Infamous039 Posted October 12, 2011 Author Report Posted October 12, 2011 Yes I had to choke for the initial start up and I let run for about 5min or so then shut it down. Every start up after that was just one kick start. Do you have to choke it? If not, your pilot is too rich. Quote
