I did see the elec diagram and read the FAQ's
I just bought a 95 , looked it over pretty good and am very happy with it. One thing I noticed they took the stock kill swich and light swich and moved them next to the gas tank plastics ( carbon fiber) with a nice swich set up. Well later I am replacing chain , sprockets ect and I notice the wiring harness is all choped up (TORS?) Fixed it. Then notice that the wiring to the new light switch is cut . It is a on off switch and realize if i can use it I can only have high beams and im fine with that. I have two wires coming from the switch , I have two yellow , a green and a blue coming from the harness . Ive tried hooking up multiple ways with no luck! the elements in the lamps look fine , also the tail light doesent work . Any reason why someone would cut all these wires? The kill swich works fine I just need lights! Any ideas???
The green is the feed for the low beam, the blue is the feed for the tailight. One of your yellows should be the "hot" feed to the switch and the other should be your high beam feed.
I got the tail light and the head lamps working off my switch. One problem was the switch was bad . I ran the green to the switch so now I guess the low beams are on , I want the high beams . I have two yellows I know witch one comes from the stator so I guess the other yellow is my high beams. It looks like both yellows come from the stator.
