Are you running lights if not you can use the lighting coil to charge a battery all you need is a suzuki lt80 rectifier ;)
thats what i am doing to charge my 12volt battery for my nitrous solenoids on my drag bike
Cheers for that chugger, I'm not running lights it's just for my flat track bike. Where about do I need to plug that rectifier in to my wiring loom?
Cheers, Paul
you can float the ground as well there are a few ways to do it
take the wire that goes from the stator to the rectifier plug that wire into the lt80 rectifier and take the other wire from the lt80 rectifier and run that to the positive batt post. ground the rect very good ground the battery very good to the frame and ground the motor very good to the chassis as well and you are good to go.
everytime the bike is running its charging the battery
works like a champ for me the lt80 rect is like 45-55 dollars.
