Im looking to buy a 4mil long rod but im unsure where to get one from. Here are my options
-f.a.s.t hot rod crank w/ extra weld
-m&m crank with max load bearing
-rdz crank
Give kevin at HJR a call. He has some good cranks as well. The life of your crank is directly related to the install, checkout, and maintenance of the crank. Check your crank with a dial gauge once you have it in your cases and have them torq'd up. Make sure the crank is still spinning true. That's a good start.
- Jared
- Jared
And what do you do if runout is off, and it's a welded crank :cheers:
If you've already been running it, send it off for a rebuild. If its a new crank send it back for a replacement.
