They are a direct bolt on. Certainly worth it in my opinion.
To compliment them I would get a master cylinder that pushes more fluid for a better feel. Either a 450 mc or a sport bike mc will work. Seems like around 17 mm mc would provide a solid feel but I think you'd have to go aftermarket for that. Most 450s use a 14mm. Maybe the ktm quads since they use twin 4 piston calipers.
Ive heard these really help bring the shee to a stop when needed. Is this worth doing? Are they really just a direct replacement, like they bolt right up?
They are a direct bolt on on 1990 and newer spindles, if you have 1989 or older spindle, you will need to get the newer style spindles.
Once you get the yfz450 front brakes you'll have to start looking for a replacement rear caliper to keep up with the front's, what's everyone running for a rear other than stock?
i would say 75% of your stopping power is the fronts, you dont have to upgrade your back brake at all. i run stock with mine.
Yes I know this, but it would be nice to have my rear brakes work just as good as my fronts. I've seen a few people running dual piston calipers in the rear, I just don't know what will bolt on directly to the banshee's rear?
