04bluyfz Posted September 8, 2011 Report Posted September 8, 2011 I am checking interest on my project, it has a hotrods 4mill longrod crank, the crank has been trued and welded and upgraded all bearings. 64.5mm 795 series pistons, stock port, noss head with pump gas domes cut for the crank. boyseen (sp) rad valve cages and carbon fiber reeds. rm stator and adjustable timing plate. the motor was just recently assembled and has only been started a couple times, less than 30 min total run time. the chassis is an 05 yfz that i made a rear mount and modified the front mounts to work. it has toomey t5s just needs the silencers piped. it also has a +4 swing arm with a brand new x-ring chain. i may also be interested in parting it out if there is interest for parts. I have about 2500 in it so i would like to get close to that for the whole thing, or make me offers on parts. Todd Quote
locogato11283 Posted September 8, 2011 Report Posted September 8, 2011 Bring it up and let me look at it before you sell it. Quote
Tallram08 Posted September 18, 2011 Report Posted September 18, 2011 Interested in motor txt 580 716 4638 Quote
04bluyfz Posted September 21, 2011 Author Report Posted September 21, 2011 not interested in parting, with the lack of interest i will probably just finish it and enjoy it. Quote
Trick2stroke Posted September 21, 2011 Report Posted September 21, 2011 What do you want for the frame? I see you have interest in the motor. The rest should be pretty easy to part out. Let me know. Quote
04bluyfz Posted September 21, 2011 Author Report Posted September 21, 2011 Interest, but no buyer. ill keep you in mind if i part it out Quote
