SpeedRacer88 Posted September 5, 2011 Report Posted September 5, 2011 I found a set of Dunlop KT335 with 90% tread for 100 shipped. They look very much like the mr501's that you recommended. I was wondering if they would perform the same. Quote
locogato11283 Posted September 5, 2011 Report Posted September 5, 2011 I just looked up that tire and I would not run those. You'd be better off running a set of stock YFZ450 tires. I don't like the shape of the lugs on those KT335. Quote
SpeedRacer88 Posted September 5, 2011 Author Report Posted September 5, 2011 stock yfz450 or mr501? which are the best? Quote
locogato11283 Posted September 5, 2011 Report Posted September 5, 2011 If you can get the 501, run them.. Otherwise grab some stock YFZ450 tires. You can probably pick them up cheap. Quote
SpeedRacer88 Posted September 6, 2011 Author Report Posted September 6, 2011 should i re gear? im at a 22" tire now mods in sig If you can get the 501, run them.. Otherwise grab some stock YFZ450 tires. You can probably pick them up cheap. Quote
locogato11283 Posted September 6, 2011 Report Posted September 6, 2011 Just depends on what you like. If you want to keep the same gearing ratio you have now you'll need to gear the bike up after switching to 20" tires. Quote
SpeedRacer88 Posted September 6, 2011 Author Report Posted September 6, 2011 i like where im at i guess Quote
