got a new 1-4 duneable overide from wcr it will not shift on every pass only some times maybe 1 pass out of 10 any suggestions thanks mike
witaker custom racing and the owner is greg. send it to him including the shift forks and he can identify the issue. another thing it can be is slipping clutches. if you have a lockup try adding weight and or replace the fibers if they are worn.
also i had the exact same prob with my 1-5 it would shift fine every couple pass but then i found out you need to have your shifter perfectly adjusted or it will not shift right
forks look good when it was pulled apart
The clutch is pretty much new only 3 rides on it
It's the fast clutch from Jeff
Yes I do have lockout what use to add weight to it
So just mess with shifter up or down?
the shift shaft has 2 centering springs. you need to adjust the ecentric bolt to make sure the hooks are centered over the shift star pins.
if everything inside is EXCELLENT!!! the shifter itself may be to low. raise it up one spot and try again a LOT of the time riders get all to anxious and wont let the shifter back down to make the next shift enough. it wont shift if the arm cannot get to the next pin..
This. Just sucks when you figure it out in the final round at a race lol
