jerseyrider Posted August 8, 2011 Report Posted August 8, 2011 on my 421 cub two weekends in a row my chain snapped in now the second time it was not the master link it was in the middle of chain ! i think but not sure i have currently a o ring chain ! what chain i need ? and why is chain snapping ? Thanks Quote
banshee4231 Posted August 8, 2011 Report Posted August 8, 2011 What type of chain you runing? only 2 real chain companies.. read this, this may be helpful.. http://www.quality-cycle.com/truth_about_motorcycle_chains.htm Quote
Gummie_guy Posted August 8, 2011 Report Posted August 8, 2011 buy a new one and keep it lubed and see if it still breaks. mine broke last year and a buddy told me that on a bike that pulls like a shee you need to keep it well lubed. Quote
AKheathen Posted August 8, 2011 Report Posted August 8, 2011 make sure your swingarm bearings are not shot, and adjust the new chain properly. should not be a problem under 80hp Quote
Jereme6655 Posted August 8, 2011 Report Posted August 8, 2011 there's a few things that can be the cause of snapping chains.......blown out swing arm bearings allowing the swing arm to move from left to right.......mis-adjusted chain.....cheap garbage chains.....no guard and you hit a rock.... Quote
shanYE west Posted August 8, 2011 Report Posted August 8, 2011 What type of chain you runing? only 2 real chain companies.. read this, this may be helpful.. I dont agree with that.. there is other quality chains other then RK and DID... Its nothing more then his opinon and promotional marketing IMO. there's a few things that can be the cause of snapping chains.......blown out swing arm bearings allowing the swing arm to move from left to right.......mis-adjusted chain.....cheap garbage chains.....no guard and you hit a rock.... I agree.. check out other componets.. carrier bearings and bad sprockets can prematurely wear chains and cause them to break. Quote
badlarry Posted August 8, 2011 Report Posted August 8, 2011 I'm pretty sure you wont find any other chain on any real high horespower machines besides regina. I've talked to numerous people who buy chains frequently, and as far as durability and not stretching it is only 1....REGINA CHAIN!! Quote
