I have seen alot about wet conditions causing issues when not using an airbox.... I have aftermarket carbs and no airbox... Is there a filter option that helps or do I have to get the airbox back? Looking at uni's with outerwears maybe our would kn be better?
I can't keep out of the puddles with my shee I have a air box with k&n air filters with the oils on the filter and a outer fine mesh and I still get some water in the air box
is it causing issues? the thread I was reading mentioned issues with the stock carbs.. don't know if maybe my flat slides solve it... or a wet filter is a wet filter
I am going through the bike tonight and giving all the electric connections a good clean and also installing a new stator rubber ,then I will try again in the same puddle and see what happens
its an odd ball problem with the 26mm stock carbs. when some of them get wet they hang up in the WOT position. However after market carbs we have no heard of doing this when they come in contact with water. So if your gonna go swimming with your bike......just make sure you keep her from hydrolocking......but you should be totally safe when it comes to having aftermarket carbs...
