codynewman13 Posted July 8, 2011 Report Posted July 8, 2011 i have a 1989 banshee for sale i cant figure out whats wrong with it i just bought brand new namura top end kit and had it installed ( have receipt for the namura top end still) when i went to kick it it wouldnt start so i pushed it around for a second and it started but was only firing on the right cylinder, and it was pouring white smoke and oil from the right pipe i dont know whats wrong with it so its going for sale, its back brakes need new pads and it comes with 2 sets of plastics one blue set thats cut in the front and in decent shape and a red set thats cut in the front and the back but the back has zip ties in it, i will also include a set of extra jugs that need bored. i will upload pics when i get home. im in middletown ohio which is inbetween cinccinatti and dayton. make me an offer Quote
Larry's Shee Posted July 8, 2011 Report Posted July 8, 2011 You had new top end "put on" By who? Even if it was your best bud, didn't they even start it? Smoke is from bad crank seal. Quote
codynewman13 Posted July 8, 2011 Author Report Posted July 8, 2011 You had new top end "put on" By who? Even if it was your best bud, didn't they even start it? Smoke is from bad crank seal. i sent my cylinders off to a machine shop got them bored to the right specs and put it together myslef, would the crank seal affect it on not firing on the one cylinder? Quote
Dicklez Posted July 9, 2011 Report Posted July 9, 2011 i sent my cylinders off to a machine shop got them bored to the right specs and put it together myslef, would the crank seal affect it on not firing on the one cylinder? Check to make sure your rings are installed properly. Quote
Larry's Shee Posted July 9, 2011 Report Posted July 9, 2011 well maybe. the right seal is sucking trans fluid. If the left was sucking lots of air it may not pull enough fuel/air to even fire. I would suggest a leak down test. Then again it could be dirty carbs. Did you clean them? How long did you actually have it running? Did you try giving left side a LITTLE shot of starting fluid while it was running? Was this running before the new pistons? Has it been sitting for a long time? More info/history needed. Quote
codynewman13 Posted July 9, 2011 Author Report Posted July 9, 2011 well maybe. the right seal is sucking trans fluid. If the left was sucking lots of air it may not pull enough fuel/air to even fire. I would suggest a leak down test. Then again it could be dirty carbs. Did you clean them? How long did you actually have it running? Did you try giving left side a LITTLE shot of starting fluid while it was running? Was this running before the new pistons? Has it been sitting for a long time? More info/history needed. i had switched the carbs over and it did the exact same thing on the right side so i dont think its the carbs, it ran about 4 months ago without pouring smoke from the right pipe like it is now. how do i go about doing a leak down test? Quote
codynewman13 Posted July 9, 2011 Author Report Posted July 9, 2011 (edited) if my rings arent installed properly could that affect the starting and the not firing on one cylinder? Edited July 9, 2011 by codynewman13 Quote
BrockMoto Posted July 9, 2011 Report Posted July 9, 2011 Yes. And theres a sticky for leak down in repair forum Quote
BrockMoto Posted July 9, 2011 Report Posted July 9, 2011 If the rings aren't seated properly you won't have enough compression causing firing and starting issues... Also hone issues if its bad Quote
mysterion Posted July 10, 2011 Report Posted July 10, 2011 there is a tube that connects the 2 carbs, make sure that is on there. Quote
