Need some opinions on fuel for my Banshee. Stock motor milled .030, 300 main jets, Duncan High Rev pipes
I was running 93 Octane ... and was told that I should run 100 octane. However -- I can't buy 100 octane in my town -- only 110 octane.
Can I mix half 93 & 110 to get the same effect?
or -- what is your opinion on running 110?
Thanks!
i believe what fuel oct u use depends on compression and timing, my comp is 170 lbs with 20cc domes and + 4 timin ,im runnin 1/2 110 vp and 1/2 93 with good results
You are fine on pump gas there is nothing to worry about. Yes you can mix 110 with pump and it works well but you have no need to do that unless you just want to run better gas
X2
