bad 350 shee Posted June 21, 2011 Report Share Posted June 21, 2011 well i putting crank seals in my banshee are there tricks to them? like i was told to pack them with grease and either glue or put yamabond around them? is that right and is there anything else? i just want to do this right Quote Link to comment Share on other sites More sharing options...
BUILDER Posted June 21, 2011 Report Share Posted June 21, 2011 I am sure some people put yamaha bond on them but I have always installed them dry and never had any issues at all. Quote Link to comment Share on other sites More sharing options...
bebetekbanshee358 Posted June 21, 2011 Report Share Posted June 21, 2011 i would only grease where the crank would ride on the seal... thats what i dop.. no problems yet.. however on my serval build i yamabond base gaskets and water plugs.......to each is own Quote Link to comment Share on other sites More sharing options...
Cali Posted June 22, 2011 Report Share Posted June 22, 2011 Your splitting the cases?I kow some people cut the liip off the seal & silicone it in.I would not recommend doing that Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted June 22, 2011 Report Share Posted June 22, 2011 The good news is, your package has left Tampa, FL. Quote Link to comment Share on other sites More sharing options...
bad 350 shee Posted June 23, 2011 Author Report Share Posted June 23, 2011 The good news is, your package has left Tampa, FL. hhahaha yah i said installing and spelled it wrong so i went to paste it and it was my tracking number lol i feel like a retard but it wouldnt let me fix it Quote Link to comment Share on other sites More sharing options...
bad 350 shee Posted June 23, 2011 Author Report Share Posted June 23, 2011 Your splitting the cases?I kow some people cut the liip off the seal & silicone it in.I would not recommend doing that yah there split Quote Link to comment Share on other sites More sharing options...
bad 350 shee Posted June 23, 2011 Author Report Share Posted June 23, 2011 but ok guys ill run them dry if no one has had problems doing so and ill put just alittle bit of grease in them thanks guys Quote Link to comment Share on other sites More sharing options...
camatv Posted June 23, 2011 Report Share Posted June 23, 2011 use OEM seals.. period.. i usually smear a very thin coat of yamah bond on the outside of the seal around the case. i have also put them in dray with no problems. never ever ever use sealer on a base gasket escpecially the paper ones it WILL blow out. Quote Link to comment Share on other sites More sharing options...
