Loc Posted June 9, 2011 Report Posted June 9, 2011 Hey guys I am having a problem with the new build. I just put together a 421 Cub engine and it has alot more power than I used to run. I am running a +4 swinger now and that is not enough. I cant keep the front end on the ground at all. I weigh in right at 135lbs and I am sure that is not helping my issue. I ride only in sand and 50/50 drag and dune. How long of a swinger are you all riding on. I know that the longer it is the harder it is to turn and function as a dune bike, but I cant ride worth a shit when the front tires never touch the ground. Thanks. Also if you have a profile pic of the bike post it up. Thanks Quote
Loc Posted June 10, 2011 Author Report Posted June 10, 2011 Glad to see no one is using a swingarm Quote
sheefreak Posted June 10, 2011 Report Posted June 10, 2011 Depends what and how much paddle you are running as well. A +6 I have found is about as much swinger as you want to put on a duner, but I have seen longer. Quote
crustydemon Posted June 10, 2011 Report Posted June 10, 2011 Gain some weight and sit on the tank. Seriously I dont think I'd want anything bigger than a +6 unless I was only dragging. I have a +4 and my front comes up on a stock cylinder bike so on a cub I suppose it would be a pain in the ass. Quote
Loc Posted June 11, 2011 Author Report Posted June 11, 2011 It really is a pain in the ass. Went over backwards and broke the tailbone a couple days ago. I was thinking either an 8 or 6 but not sure if the 6 would offer much help. Quote
sangheraent Posted June 11, 2011 Report Posted June 11, 2011 i run a +8 on my stock cyl 4mill and I love it. I can wheelie up any hill and with a little effort I can wheely in flat areas. I thought it would be too long but I can get all my power to the ground on big hill climbs and that was not even close to being possible with the stock swinger. Quote
crustydemon Posted June 11, 2011 Report Posted June 11, 2011 Correction on my last post, mine is a 6 over not a 4. So yes, a +8 might not be bad. Quote
06specialedition Posted June 17, 2011 Report Posted June 17, 2011 For a all around dune and hill shooter IMO +4 to +6 is best. Any bigger than +6 and they just don't dune as well. I'm running a Stellar +4 on my duner and wouldn't have it any other way Quote
10milmike Posted June 17, 2011 Report Posted June 17, 2011 I run a +8 in on a 10mil, The Bike comes up a little but all I do is lean my fat ass forward and in comes down..now on dune bike I run a+ 6 and it is great in the dunes at Glamis. Quote
mitty8251 Posted June 17, 2011 Report Posted June 17, 2011 with your weight I would def. go with a +8 but depends on your gearing and the paddle you are running. You can run a little more pressure in your tires to help keep the front end down but you will be giving up traction. Play with gearing, # of paddles and tire pressure to get what you want. You should be able to get the front end under control with those changes and your current length of swing arm. Quote
dcalsv02 Posted June 17, 2011 Report Posted June 17, 2011 I am a 50/50 drag dune guy as well. only ride in sand. I have +4 and will keep it that way. I weigh 170. try working your clutch a little. feather it to keep the front end down. or become intimately familiar with your foot break. Along with all the other suggestions above. check my profile to see my bike if you want. Quote
Bones30 Posted June 22, 2011 Report Posted June 22, 2011 My brother had a 4 mil cub, 94 hp, 175lbs, running 12 paddle ultra lites. He tried running with a 6 but it wasn't effective. Switched to an 8 and loved it but lost a little dunability. I can imagine that is more than a handful on a 4. Quote
BUILDER Posted June 22, 2011 Report Posted June 22, 2011 I have a 421 also and I am running a +5 right now and I weigh 220 and it is very hard for me to keep it on the ground if I am drag racing. I am going to build one 2 inches longer and see if that will help. I do lots of tree shots and trail riding so I am going to try and keep it as short as I can but want to be able to launch it when I am racing also. Quote
bansheeboy44 Posted June 23, 2011 Report Posted June 23, 2011 +8 all the way. I've ran banshees w/ stock, +4, +5, +6, and +8. The longer you go the less fun it is to dune, but should avoid you cracking you tail bone again. Get well soon! Quote
