i got a free banshee from my girlfriend's dad, but it needs a new crank because one of the rod bearings is out, so i'm doing a full rebuild, and i was hoping for a little help with what all i need to buy/have done. tell me what i'm forgetting
cylinders bored
cylinders ported
new crank, welded
top end rebuild kit (gaskets and pistons and such)
bottom end rebuild kit (new crank, bearings, seals)
the transmission and clutch are both new
it needs a new clutch cable
carb rebuild kits
reed petals
that's all i can think of right now, what else needs to be done?
Dont for get Yamabond #4 to seal the cases and get a fresh clutch kit since you dont know the history of the bike.
I did a bottom end rebuild walk-through. Its a sticky at the top of the repairs and mods section. Check it out if you have any questions on the rebuild.
i've always seen stuff about the pancake bearings but idk what they are, could someone help me out?
and how would i be able to tell if the idler gear bearing is bad?
A Clymers manual...I'm not being a smartass either!!! That book was the best thing I have every purchased for my bike. It realy helps out when you forget where a piece goes, torque spec, adjustments, ect. I'm not second guessing your mechanical ability at all.... good luck with the rebuild! :cheers:
