eldreder Posted May 26, 2011 Report Posted May 26, 2011 i got a free banshee from my girlfriend's dad, but it needs a new crank because one of the rod bearings is out, so i'm doing a full rebuild, and i was hoping for a little help with what all i need to buy/have done. tell me what i'm forgetting cylinders bored cylinders ported new crank, welded top end rebuild kit (gaskets and pistons and such) bottom end rebuild kit (new crank, bearings, seals) the transmission and clutch are both new it needs a new clutch cable carb rebuild kits reed petals that's all i can think of right now, what else needs to be done? Quote
Infamous039 Posted May 26, 2011 Report Posted May 26, 2011 Dont for get Yamabond #4 to seal the cases and get a fresh clutch kit since you dont know the history of the bike. Quote
Phelps Posted May 26, 2011 Report Posted May 26, 2011 water pump and seal. if the bike is very old, or never had the coolant changed the impellers fall apart. Quote
BigRed350x Posted May 26, 2011 Report Posted May 26, 2011 I did a bottom end rebuild walk-through. Its a sticky at the top of the repairs and mods section. Check it out if you have any questions on the rebuild. Quote
06specialedition Posted May 26, 2011 Report Posted May 26, 2011 Pancake bearing, Modded shift star, Idler gear bushing. Quote
eldreder Posted May 26, 2011 Author Report Posted May 26, 2011 i've always seen stuff about the pancake bearings but idk what they are, could someone help me out? and how would i be able to tell if the idler gear bearing is bad? Quote
blubyyou Posted May 27, 2011 Report Posted May 27, 2011 A Clymers manual...I'm not being a smartass either!!! That book was the best thing I have every purchased for my bike. It realy helps out when you forget where a piece goes, torque spec, adjustments, ect. I'm not second guessing your mechanical ability at all.... good luck with the rebuild! Quote
