Zwiser Posted May 17, 2011 Report Posted May 17, 2011 So i replaced all the a arm bushing but the upper right a arm, the bolt is stuck, i tried every thing i can think of and it doesnt budge, any suggestions? Quote
Zwiser Posted May 17, 2011 Author Report Posted May 17, 2011 someone on the impact, unscrewing it, and someone uses a hammer to hit it? or use a thick phillips head screwdriver and beat it out? spray with pb blaster first though. tried the impact and pb blaster, i think the bolt might be bent? and i used a punch insdide of a screwdriver to beat it out but still didnt budge? Quote
Coupelx Posted May 17, 2011 Report Posted May 17, 2011 i had to cut mine off. since you want to reuse the arm, center punch and drill both ends of the bolt off. Quote
Zwiser Posted May 17, 2011 Author Report Posted May 17, 2011 i had to cut mine off. since you want to reuse the arm, center punch and drill both ends of the bolt off. but how am i soppused to get the bolt out if i drill the ends off? i belive the bolt is bent like in the middle of the arm Quote
Larry's Shee Posted May 17, 2011 Report Posted May 17, 2011 After you get rid of the head and threaded end past mounting point, pull arm, thro center sleeve away. Quote
Coupelx Posted May 17, 2011 Report Posted May 17, 2011 you will have to replace the sleeve and the bolt. you drill the ends off so you can get the a arm off. you could use a die grinder if you are careful. I tried alot of things to save the bolt in mine. easier just to buy a new one from bikebandit.com for $4 i think they offer the sleeve too if your rebuild kit didnt come with them. Quote
Zwiser Posted May 17, 2011 Author Report Posted May 17, 2011 yeah its not going anywhere i guess ill just have to do what you suggested, thanks Quote
Zwiser Posted May 18, 2011 Author Report Posted May 18, 2011 i tried a air hammer, it didnt budge Quote
camatv Posted May 26, 2011 Report Posted May 26, 2011 just cut it off and buy new. they are pretty cheap. you probably spent more in running the air tools and all the pb blaster, rust eater adnd time to try to save a 3 dollar bolt.. Quote
Zwiser Posted May 27, 2011 Author Report Posted May 27, 2011 i did driil it out, but i hd to press it out of the a arm afterwards. Quote
