qtszx14 Posted May 17, 2011 Report Posted May 17, 2011 i have a banshee that was set up to run on gas or alky the bike have powerjets in the carbs the guy i brough the bike from gave me xtra jets and colder plugs and said its ready to run i lost the parts and need help to get going u can call me 205-718-6518 with info on what to do Quote
sleeper06 Posted May 18, 2011 Report Posted May 18, 2011 if its a pwk carb you cant just switch,lectrons are diffrent but your changing more than jets Quote
qtszx14 Posted May 19, 2011 Author Report Posted May 19, 2011 the guy i brought the bike from had run it with alky the carbs are 40 with powervalves he gave me a set of jets and some colder sparkplugs i lost them need to know how far to go up on the main jets and what plugs and oil to mix with alky you can call me 205-718-6518 Quote
tedd1 Posted May 20, 2011 Report Posted May 20, 2011 If they are Lectron carbs, call Packard. They will hook you up. If they are any other brand, it is way more complicated than that... Quote
BigRed350x Posted May 23, 2011 Report Posted May 23, 2011 What kind of carbs do you have? Keihin, Mikuni, Lectron, etc... What is your current main jet size, current dump tube size, needle size, pilot jet size... We need more information to be able to help you get it set up right. I NEVER trust anyone else's jetting or setup. I will always start over and re-jet the bike myself. Just because the guy told you it was set up to run alky doesn't mean he knew what he was doing or had the setup right. Tell us: Elevation Average Temp where you ride Main jet size Dump Tube Size Needle size Pilot size how many turns out on the power jet are you? compression timing advance pickup coil gap plug type plug gap Do you have all the other supporting mods to run alky? Gas cap modded, pingle, billet bowls, etc... Quote
camatv Posted May 26, 2011 Report Posted May 26, 2011 oh thats too much work go get alky mix it 32-1 with KLOTZ or CASTROL 927 ONLY gap your plugs at .18 dril the dump tube to . 125 drill a set of mains to .120 drop needle all the way down install 50 slow jets install a pingle fuel valve drill out and remove all the guts out of yoru stock cap OR buy a billet cap and make sure it has no valve in it. NO fuel filters put all that in set carbs accordingly synch wise and turn PJ at about 2 turn out pray it all works.. if you cannot figure that out sell the bike Quote
qtszx14 Posted June 7, 2011 Author Report Posted June 7, 2011 need a mechanic close to alabama call me 205-718-6518 need help with alky Quote
camatv Posted June 8, 2011 Report Posted June 8, 2011 did you read that post?? the one right up there . /\ / \ / \ Quote
