i have a banshee that was set up to run on gas or alky the bike have powerjets in the carbs the guy i brough the bike from gave me xtra jets and colder plugs and said its ready to run i lost the parts and need help to get going u can call me 205-718-6518 with info on what to do
the guy i brought the bike from had run it with alky the carbs are 40 with powervalves he gave me a set of jets and some colder sparkplugs i lost them need to know how far to go up on the main jets and what plugs and oil to mix with alky you can call me 205-718-6518
What kind of carbs do you have? Keihin, Mikuni, Lectron, etc... What is your current main jet size, current dump tube size, needle size, pilot jet size... We need more information to be able to help you get it set up right. I NEVER trust anyone else's jetting or setup. I will always start over and re-jet the bike myself. Just because the guy told you it was set up to run alky doesn't mean he knew what he was doing or had the setup right.
Tell us:
Elevation
Average Temp where you ride
Main jet size
Dump Tube Size
Needle size
Pilot size
how many turns out on the power jet are you?
compression
timing advance
pickup coil gap
plug type
plug gap
Do you have all the other supporting mods to run alky? Gas cap modded, pingle, billet bowls, etc...
oh thats too much work
go get alky
mix it 32-1 with KLOTZ or CASTROL 927 ONLY
gap your plugs at .18
dril the dump tube to . 125
drill a set of mains to .120
drop needle all the way down
install 50 slow jets
install a pingle fuel valve
drill out and remove all the guts out of yoru stock cap OR buy a billet cap and make sure it has no valve in it.
NO fuel filters
put all that in set carbs accordingly synch wise and turn PJ at about 2 turn out pray it all works..
if you cannot figure that out sell the bike
  • 2 weeks later...
