Bansheecrazy23 Posted May 16, 2011 Report Share Posted May 16, 2011 I am the original owner of an 02 banshee it is pretty much stock. It has toomey t6 pipes, vforce reeds, k&n off carb filters, and a few other cosmetic bolt ons! Well it's time for a top end rebuild! I was wondering what y'all would suggest! I would like to make 60+hp, but keep it reliable and easy to maintain. All my buddies 4 stroke bikes are making about 50hp! I would like to woop em and get the last laugh. What would be the cheapest way to accomplish this? We ride mostly in the dunes! Quote Link to comment Share on other sites More sharing options...
madjimmax Posted May 17, 2011 Report Share Posted May 17, 2011 Hey bro welcome to the site. If I was you I would send the cylinders and head out to one of the site sponsors and get your self a dune port, head rechambered and shaved, ditch the T-6s and get a set of T-5s, and pickup an adjustable timing plate and advance your timing 4 degrees, Billet waterpump impeller, then throw a set of 33 PWKs and you'll be kicking their ass. I had Jeff @ FAST do all my port work he's a first class guy who knows how to make em go fast. Quote Link to comment Share on other sites More sharing options...
NYUK Posted May 17, 2011 Report Share Posted May 17, 2011 4 mil, ported. game over. Quote Link to comment Share on other sites More sharing options...
Profilact Posted May 17, 2011 Report Share Posted May 17, 2011 +2 On Jeffs work. Without a doubt you will be spanking them if you have your stock cyl's ported. Jeff is a super nice guy to deal with and his work is second to none. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted May 17, 2011 Report Share Posted May 17, 2011 The most reliable power you can make is with porting. A good port job, +4 timing and a good set of pipes. Those t6's will choke up a port job. Quote Link to comment Share on other sites More sharing options...
gotta_goatsfast Posted May 17, 2011 Report Share Posted May 17, 2011 I think my Serval makes very good ridable torque and an easy powerband.... and I'm much above your 60hp goal. Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted May 17, 2011 Report Share Posted May 17, 2011 If you're just looking for around 60 on pump gas then a hardcore MX port ought to work with a good set of pipes, K&N filter/adapter or pods, +5 timing, and all the other goodies to go. I've heard of a 'shee or two coming from Herr Jugs making that kind of power with stock carbs, shaved head, and the aforementioned mods. I don't think it's too uncommon for that kind of setup but the others' opinions on the 4mil, larger porting, bigger carbs, etc. would make that number a lot easier. Quote Link to comment Share on other sites More sharing options...
camatv Posted May 17, 2011 Report Share Posted May 17, 2011 t-6's are a great "trail/ rider pipe with proper porting they make KILLER botttom end and make the bike VERY rideable and tqy. just need done right the rebuild alone will make the bike seem new to you. i redid a STOCK 04 with new top end and t=6's on the road it steady pulled from a 450 with a big bore cylinder on it. stock airbox, proper jetting, and K+N filter kit. it was a blast in the dirt.. Quote Link to comment Share on other sites More sharing options...
robert.b.west Posted May 17, 2011 Report Share Posted May 17, 2011 (edited) Hey bro welcome to the site. If I was you I would send the cylinders and head out to one of the site sponsors and get your self a dune port, head rechambered and shaved, ditch the T-6s and get a set of T-5s, and pickup an adjustable timing plate and advance your timing 4 degrees, Billet waterpump impeller, then throw a set of 33 PWKs and you'll be kicking their ass. I had Jeff @ FAST do all my port work he's a first class guy who knows how to make em go fast. This was my last setup except just a stock head. No problem beating the 450's. Probably the cheapest of all the ways listed. A +4mm stock cylinder and a serval would have no problem beating them (and would have more power) but also cost more. Edited May 17, 2011 by robert.b.west Quote Link to comment Share on other sites More sharing options...
06specialedition Posted May 17, 2011 Report Share Posted May 17, 2011 Wildcard Aggressive Dune Porting, CPI's, +4 Timing = 65HP Quote Link to comment Share on other sites More sharing options...
CFH87 Posted May 17, 2011 Report Share Posted May 17, 2011 HJR dune port, shearer pipes, cool head and domes for pump gas for your elevation, 4 mil or stock crank, stock carbs and it'll be a ripper. I had Kevin also do my cyls and crank should be in the 60's with 19cc domes and race gas for my setup. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted May 18, 2011 Report Share Posted May 18, 2011 Send your cylinders off to Kevin at Herr Jugs Racing. He will hook you up with a port job and any of the bolt-on parts you need. Great guy to deal with and he does some top-notch work. Quote Link to comment Share on other sites More sharing options...
