Gunner1 Posted May 7, 2011 Report Share Posted May 7, 2011 hi!! help!!!!! putting some tlc into my new banshee just got finished cleaning carbs, replaced rear sprocket and caliper, i had it up and sitting on end,i was taking the rear sprocket skid plate off. and i got it all put back together and know the powerband will not kick in, it just sputters through all gears and never takes off..... i think i might have flooded the reeds?? or ??? i put new plugs in it and pulled them and they looked alittle black could running it to lean keep the powerband from kicking in?? air filter looks good nothing in there..... carbs seem to be synced and i have good compression.. starts fine and revs fine.... if i lift the rear axle and let the tires spin it sounds like the powerband is kickin in.... its a 98 banshee fmf fatboys, jetted 240, stainless water impelller, motor was rebuilt in 2003 i thinki or 04, i think the cdi is stock could that of went bad? thanks for the help....!!!!! Quote Link to comment Share on other sites More sharing options...
Gunner1 Posted May 7, 2011 Author Report Share Posted May 7, 2011 o yeah its been converted too Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted May 7, 2011 Report Share Posted May 7, 2011 o yeah its been converted too What's been converted?????????????????? Black plugs mean you are rich, however with pipes on it you should need bigger jets than 240s unless you are at high altitude. Quote Link to comment Share on other sites More sharing options...
Gunner1 Posted May 7, 2011 Author Report Share Posted May 7, 2011 The rev box Quote Link to comment Share on other sites More sharing options...
Gunner1 Posted May 8, 2011 Author Report Share Posted May 8, 2011 i stood it on it on the grab bar to work on the sprocket shield... flooded something just not sure what to do or check...... Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 8, 2011 Report Share Posted May 8, 2011 Banshees don't have "rev" boxes. Do you mean aftermarket "cdi" box? Does it still have TORS ? Stock carbs? Clean carbs one at a time. Quote Link to comment Share on other sites More sharing options...
sicK Shee Posted May 16, 2011 Report Share Posted May 16, 2011 Sounds like an elictrical issue, check ur coil make sure its getting good ground n that all the wires are connected, if everything looks fine try a dif coil.. Friend of mine had same issue last wknd at Dumont, we replaced the coil n the sputtering went away.. hope this helps. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted May 16, 2011 Report Share Posted May 16, 2011 did you take the carbs apart at the same time? it is possible to put the wrong slides backwards in the opposite carbs.....and it is also possible to put the wrong carb bowls on the wrong carbs. pull the air filter and look at the slides......the half moon cut out should be visible from the backside of the bike (air filter side of motor) also look at the bows.....the carb bowl are side specific. the carb bowl that has a brass ball on it should be on the choke side carb. if you managed to flood it then you can take the pipes off and pour the fuel out of the pipes. then kick it over with the ignition turned off to get any extra out of the engine cases...... then report back... Quote Link to comment Share on other sites More sharing options...
bansheelover22 Posted May 25, 2011 Report Share Posted May 25, 2011 hi!! help!!!!! putting some tlc into my new banshee just got finished cleaning carbs, replaced rear sprocket and caliper, i had it up and sitting on end,i was taking the rear sprocket skid plate off. and i got it all put back together and know the powerband will not kick in, it just sputters through all gears and never takes off..... i think i might have flooded the reeds?? or ??? i put new plugs in it and pulled them and they looked alittle black could running it to lean keep the powerband from kicking in?? air filter looks good nothing in there..... carbs seem to be synced and i have good compression.. starts fine and revs fine.... if i lift the rear axle and let the tires spin it sounds like the powerband is kickin in.... its a 98 banshee fmf fatboys, jetted 240, stainless water impelller, motor was rebuilt in 2003 i thinki or 04, i think the cdi is stock could that of went bad? thanks for the help....!!!!! do banshees come stock with a power band and how do you know if it is working Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted May 25, 2011 Report Share Posted May 25, 2011 do banshees come stock with a power band and how do you know if it is working it depends how far you stretch it.....sometimes if you stretch it too far it'll snap.... haha Quote Link to comment Share on other sites More sharing options...
toytech Posted May 25, 2011 Report Share Posted May 25, 2011 do banshees come stock with a power band and how do you know if it is working yes, It maybe worn out though. I got my new powerband at F.A.S.T. racing, what an improvement. Quote Link to comment Share on other sites More sharing options...
red04 Posted May 30, 2011 Report Share Posted May 30, 2011 yes, It maybe worn out though. I got my new powerband at F.A.S.T. racing, what an improvement. dood! gotta get one of those two!...... Quote Link to comment Share on other sites More sharing options...
