bansheelover22
Everything posted by bansheelover22
  1. okay i have a pro design cool head if the orings leak would it cause my radiator to blow antifreeze out the overflow tube and would it pressurize my bottom end and miss cause i started it up today and it blew antifreeze out the exhaust it backfires, blow antifreeze out over fllow and blows oil out trans vent tube
  2. well i took my fly wheel off it had a timing advance key in it with the hang over part towards the front of the engine and it looked like the flywheel had been moving on crank a little the key was a little loose in the key slot i think im going to put a stock key in it o and i mix my fuel at 32:1 with 93 octane and klotz super is that the right mix
  3. i finally got to got the shee together and started i had it running in the garage the other day it would idle fine it would rev fine but now it backfires and is hard to start i had to put gas into spark plug holes to get it to start today any ideas
  4. do banshees come stock with a power band and how do you know if it is working
  5. i noticed my banshee has a ticking noise when running or even if youtook the flywheel cover off and turned it over by spinning the fly wheel and i noticed the vent tube has oil leaking from it when running is this normal im new to banshees
  6. have you guys ever had oil coming out of the hose when it is running or any ever had this
  7. hi im new to this site i am thinkinhg of trading my 2004 suzuki ltz400 for a 1989 banshee do you think this is a good idea the banshee needs the topend and bottom end changed he has the parts i just got to tear it bown and install it all
