Hey guys, I am looking to save some weight on my axle, is the G force any lighter? If not, what is? I would like to get a couple inches of width if possible
thanks.
  • Like 1
g-force will be heavier.. there isn't a huge difference in weight savings with moly.. the properties of moly is what makes it more ideal. Also.keep in mind that not only is there more material to make it stronger.. but its also 4" longer.
ok, so where is the best place to save weight, that costs the least as well? I am thinking about a swing arm from stellar.
I run a Stellar +4 and it seems to be lighter than stock. And going to the round house carrier is the only way to have it IMO.
Thats what I am thinking, I would like to weigh a stock swinger, so I can have a real idea of weight savings.
I found a pretty good deal on a RAD titanium axle with all billet hubs. It's lighter than stock but pricey and hard to come across used.
The swing arm and tire/rim set up is probably your best bet for weight savings.
it starts with the gut.....its the easiest way to get rid of weight while saving money.....shit just cut a meal out and you'll be saving money that way.
X2, that makes a HUGE difference. I've lost 55lbs since last summer, I'm excited to ride now :D
the gforce weighs more than the stocker.
jj&a 40mm play axle is the way to go. i just put one on my banshee and its way lighter than the stocker.
its pretty stout too. flipped my shit end over end about (4) times, first time out and its still straight as an arrow. :)
thanks.
What about the Blaster axle??
..just wondering
-Pasi S.
jj&a all the way helps rotating mass and looks real tuff,anything keyed is the shit,oh an you want adjustable its got it, they make a play axle 28in,drag26in
