jjn56 Posted April 28, 2011 Author Report Share Posted April 28, 2011 dump some pre mix down the plug holes if it fires its carb Tried that, still didn't fire, put in about 1/2 a small surenge full, is that to much? not enough maybe? Quote Link to comment Share on other sites More sharing options...
jjn56 Posted April 28, 2011 Author Report Share Posted April 28, 2011 He said the plugs are wet. You might want to make sure your cases and/or pipes are not flooded with fuel. Take the plugs out, turn the bike upside down and roll the engine over with the kicker to see if fuel comes out. When the fuel quits coming out, put the bike right and let it sit for awhile with no plugs to air out. Then install new plugs and see if it will start. Tried this one already, had this problem about a year ago before I rebuilt my carbs. took the pipes off and no fuel in them, kicked it and nothing came out of the crank. Thanks! Quote Link to comment Share on other sites More sharing options...
jjn56 Posted April 28, 2011 Author Report Share Posted April 28, 2011 bump, compression left side 128 right side 132 Quote Link to comment Share on other sites More sharing options...
banshee95purple Posted May 11, 2011 Report Share Posted May 11, 2011 If I have spark and my stator and pickup coil Ohm's are OK can my stator still be bad. Little history, bike ran fine, decided to get an adjustable timing plate, installed it per instructions, wouldn't start, Thought I possibly may have damaged the stator while taking the flywheel off (bent a pole) so I bought a used stator off ebay (RM Stator 200w), Still won't start. Has fuel, has spark, still wont start at all, Ohm'ed the kill switch, and key switch also, both OK. Basically I'm to the point of do I buy another stator or a try a CDI next. Any help is appreciated. Have you tried putting the old timing plate back on? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted May 11, 2011 Report Share Posted May 11, 2011 Are you sure the key is installed properly_ some times they slip out of position when you slide the flywheel on and then it will be out of time. Quote Link to comment Share on other sites More sharing options...
jjn56 Posted May 11, 2011 Author Report Share Posted May 11, 2011 Thanks, I'll look at the timing again and report back. Quote Link to comment Share on other sites More sharing options...
