06BCBANSHEE Posted April 21, 2011 Report Posted April 21, 2011 so because i didnt realize i have long travel a arms, i now need to order some shocks. I got some quotes from works performance i have narrowed it down to a few. 1) pro piggy back 2 w/triple rate springs threaded preloud and adjustable compression damping piggyback reservoirs $965 a pair 2) Pro G3 triple rate springs, threaded preload , dual line high speed compression adjustable remote reservoirs and adjustable rebound damping $1239 a pair 3) pro piggyback3 triple rate springs, threaded preload, adjustable compression dampening piggyback reservoirs, and adjustable damping @ $1105 a air 4) black widow piggyback 4 triple rate springs, threaded preload, high and low speed adjustable compression damping piggyback reservoirs and adjustable rebound damping $1219 5) pro G4 threaded preload, dual line high and low speed compression adjustable remote reservors and adjustable rebound dampening $1325 a pair I ride mostly trails, but i ride them fast and hard. I would like to start hitting the track. I dont see me hitting 60-100 ft jumps, but who knows maybe if i had good suspension i might I would like to stay around the $900-1100 range. But If it is worth it to spend the extra couple hundred dollars then i would consider the more expensive options. appreciate your input guys. After i purchase these I will be getting a elka elite long travel rear shock as well. Dont really need it but i found one for $750 with long travel linkeage. lemme know what you guys think Quote
06BCBANSHEE Posted April 22, 2011 Author Report Posted April 22, 2011 Also anyone ever ordered from precision powersports? They can get me stage 2 elkas with adjustable compression and pteload for $940 shipped to my door. Seems like a pretty good deal to me. Need input guys!!!! Want new shocks, and its riding season! Quote
Larry's Shee Posted April 22, 2011 Report Posted April 22, 2011 Presume you have arms set up for longer shocks? Snatch up that rear, seems the link alone is 5-600. As to the fronts, I have no knowledge Quote
thomas h. Posted April 23, 2011 Report Posted April 23, 2011 the guys @ leager like the fox float evol because it is lighter that most shocks and it is adjustable to your conditions they start around 1400.00 but no revalving or oil to change. Quote
06BCBANSHEE Posted April 25, 2011 Author Report Posted April 25, 2011 still not too much input well im prob gonna order the stage 2 elkas. $840 shipped to my door seems like a good deal. anyone order from precision powersports? wanna make sure their a legit/good company before i give them $900. Quote
