my carbs were cleaned last weekend so surely thats Not the problem.
Allot of the time the problem comes from "fixing" it, I always try to find out what was f'ed with last on an (any) engine so I can focus my attention there after I do a visual, comp. test, and then spark check. Expecially if the carbs were just messed with...pull em off and check em out.
Well i put the old reeds back in today and it was a bit better and all of a sudden after it not running right for about an hour, its banding on both sides, the only thing i can think of is dirt in the carb must of moved or something?
Still don't know if its running right, in 1st gear it goes really slow and like really high revs and the same for the rest of the gears, its seems to be in sixth aswell pinned and it feels just so slow for a banshee, it feels as if i should be pulling into another gear and taking off, as soon as you hit the powerband the revs stay the same no matter how much throttle, i expecting it to go alot faster, maybe im just getting used to it but i done know..??????
Old reeds are back in and the reason im finding it slow is deffinitely because its only going into the band on one side. It's using a whole loads fuel too..a tank only gets me about one hour riding time, maybe one and a half. I've switched coils round, no change, switched plugs, no change, flipped reeds no change. Both cylinders run well at idle but when you start to go into higher rpm thw left side kinda breaks up..
Well stop running it and check it all out. Obviously something major is wrong but be my guest an run it till it blows cause thats whats gonna happen if you keep pushing it. Youve wasted atleast 2 tanks of fuel already....i woulda stopped when I felt something wrong the first time
