TORQUEDFORD Posted April 11, 2011 Report Posted April 11, 2011 I have a couple of questions about a engine build i am doing. There are 4 epoxied holes in the bottom of the case under the crank. Most guys I think just grind around the area on the bottom and add more epoxy. Has anyone tried drilling and tapping the holes from the bottom and Loc-Tite some set screws in there? Those holes look to have plenty of meat to thread, they go all the way to the crank bearing, I was thinking I would only thread them in flush with the bottom of the case. Quote
n2otoofast4u Posted April 11, 2011 Report Posted April 11, 2011 What? I dont follow. You got a picture? Quote
TORQUEDFORD Posted April 11, 2011 Author Report Posted April 11, 2011 What? I dont follow. You got a picture? I dont have a picture. If you look at a bottom case half, on the outside, in the center where the crank sits, there are 4 epoxied holes from the factory. The holes are about 1/4" or smaller. Over time that can be a potential air leak, sometimes they start to weep a little. Quote
bansheesandrider Posted April 12, 2011 Report Posted April 12, 2011 I dont have a picture. If you look at a bottom case half, on the outside, in the center where the crank sits, there are 4 epoxied holes from the factory. The holes are about 1/4" or smaller. Over time that can be a potential air leak, sometimes they start to weep a little. I have never seen a set of cases that had epoxied holes from the factory. Sounds like somebody has been there before. Quote
Jereme6655 Posted April 12, 2011 Report Posted April 12, 2011 never seen that before either.....factory epoxy? someone has been inside your cases before. Quote
