rb0804 Posted April 6, 2011 Report Posted April 6, 2011 I have seen some suspened single a-arm chassis around that look like they use some sort of a strut, complete with the spindle. Does anyone know where I can get these struts? I can post some pictures later on if it will help out. Thanks. Quote
joee20002 Posted April 6, 2011 Report Posted April 6, 2011 I have seen some suspened single a-arm chassis around that look like they use some sort of a strut, complete with the spindle. Does anyone know where I can get these struts? I can post some pictures later on if it will help out. Thanks. call tyson racing....................... Quote
Larry's Shee Posted April 6, 2011 Report Posted April 6, 2011 Educate me. Purpose of using that section of stock frame? Quote
shanYE west Posted April 6, 2011 Report Posted April 6, 2011 Oh Joee, no love for us site sponsors? Its ok Tim.. I still love ya.. Quote
rb0804 Posted April 6, 2011 Author Report Posted April 6, 2011 In that pic we have mockup struts in place for the build. But you would normally have a Marvin Shaw shock in its place for dune racing, or you could use a lightweight strut for track racing as well. Thanks for the reply, I sent you a PM. Quote
SlowerThanYou Posted April 7, 2011 Report Posted April 7, 2011 Thanks for the reply, I sent you a PM. Our Stock frame was set-up with a single a-arm on each side. Quote
rb0804 Posted April 7, 2011 Author Report Posted April 7, 2011 Have any pictures floating around Brian? I am interested in the strut deal for weight. Quote
SlowerThanYou Posted April 7, 2011 Report Posted April 7, 2011 (edited) We still don't have this set-up the way I like. We need to modify it to hopefully get it where I will be happy. There's nothing wrong with the workmanship, but something is wrong in the geometry. Yes, it has front brakes. Edited April 7, 2011 by SlowerThanYou Quote
rb0804 Posted April 8, 2011 Author Report Posted April 8, 2011 We still don't have this set-up the way I like. We need to modify it to hopefully get it where I will be happy. There's nothing wrong with the workmanship, but something is wrong in the geometry. Yes, it has front brakes. Looks neat Bryan where did you come up with the struts at? I'm looking for a place to purchase the struts with the spindle, etc so all I have to do is fab the top shock mount and the lower a-arms. Quote
SlowerThanYou Posted April 9, 2011 Report Posted April 9, 2011 Looks neat Bryan where did you come up with the struts at? I'm looking for a place to purchase the struts with the spindle, etc so all I have to do is fab the top shock mount and the lower a-arms. The strut is a Marvin shaw shock. The spindle has to be made custom. I would be more specific in description & photos, but the set-up is not right yet. Quote
rb0804 Posted April 11, 2011 Author Report Posted April 11, 2011 The strut is a Marvin shaw shock. The spindle has to be made custom. I would be more specific in description & photos, but the set-up is not right yet. So a regular Marvin Shaw slides into the spindle setup? Where can I get a spindle custom made? Does the spindle clamp the shaw in there some kind of way so that it doesn't pop out? How do I get ahold of you? I used to drop you a PM here from time to time and I thought about doing it before I started this thread, but didn't. I went back and looked the other day because I was curious about a few things, but I didn't see a PM option. Thanks for everyones' replies thus far. Quote
SlowerThanYou Posted April 12, 2011 Report Posted April 12, 2011 I'm not going to point anyone in the direction until I get this figured out. If I could change back to my custom double a-arm, I would. It was set-up for really stable steering at 120+ mph. When I get it figured out I will be happy to share the information. Quote
banshee332 Posted April 12, 2011 Report Posted April 12, 2011 I'm not going to point anyone in the direction until I get this figured out. If I could change back to my custom double a-arm, I would. It was set-up for really stable steering at 120+ mph. When I get it figured out I will be happy to share the information. I could be wrong but from the pic. I think the shock is in to steep of an angle. If you would set it up to be more straight up and down that might help. Just a suggestion Quote
SlowerThanYou Posted April 12, 2011 Report Posted April 12, 2011 I could be wrong but from the pic. I think the shock is in to steep of an angle. If you would set it up to be more straight up and down that might help. Just a suggestion That would go the wrong direction. When you lay the strut back (+ Caster) it provides straight line stability. We built it with 15* + caster. I think the problem lies more in the steering ratio. Quote
SlowerThanYou Posted April 12, 2011 Report Posted April 12, 2011 Here's something I used to explain it a couple years ago. http://www.stockcarracing.com/tipstricks/camber_caster_toe_setup/index.html Quote
