banshee jump Posted April 5, 2011 Report Posted April 5, 2011 hi, could someone give me step by step instructions on how to change the banshee transmission oil since its my first time doing it at home Quote
Jereme6655 Posted April 6, 2011 Report Posted April 6, 2011 stick hand under banshee and use wrench to remove the drain bolt on the bottom of the motor. let fluid drain out. put drain bolt back in and tighten. remove fill plug on your trans. fill with required amount and correct fluid. Quote
Ranger08 Posted April 6, 2011 Report Posted April 6, 2011 but which one, there is 3 ? The one thats not connected to your lower engine mounts.....should be a 17mm Quote
