justinkk2005 Posted April 5, 2011 Report Posted April 5, 2011 Hey guys, I just done a plug chop and i'm still lean as shit with a 165 main and 55 pilot on pwk 28's, no WAY it's right with a n68a needle on the 5th position (richest) Well I looked back in the slide and I saw this little brass looking piece sticking up out of the carb where the needle goes down into the carb, the other carb it isn't like that. So I tried to press it back down and it wouldn't go, I pulled the main jet out the whole piece there that it screws up into and it went down, as soon as I threaded that back into it the piece came back up again, is that normal or should it be flat? Quote
justinkk2005 Posted April 5, 2011 Author Report Posted April 5, 2011 one is actually longer than the other? any ideas? can i just grind them down to be the same size Quote
sstaton1983 Posted April 5, 2011 Report Posted April 5, 2011 i think you are talking about the dump tube coming loose.they should be the same on both carbs. Quote
