what could i use to clean exhaust ports, intake ports, cylinder head, and the piston and crank? could i take gasoline and wipe them down? just to remove the black residue? i know to spray carbs with carb cleaner lol. a little help please
I use simple green for the case, carbs, (outside of carbs) and cylinders..are you talking about internals?
thankyou! and yes internals also lol. i got this stuff ecoorange that ill use for the stuff you listed lol
Brake cleaner w/o chlorine & Carb Cleaner. You can use that stuff to clean everything on the banshee engine.
thanks man! appreciate it!
