I've just removed the stock control switch for an aftermarket one as I need to fit a horn, indicators etc for making it road legal, my banshee is a 2002 model and has seven different wires going into it this is what I've made out from the diagram on the electrical thread:
Green. Low beam
Yellow. High beam
Black. Ground
Black/white. Cut off switch
There are 3 other wires but im not sure what they do or go to
Blue
Red
Red/yellow
Does anyone know what these wires are and what I need to connect them to?
Also if I connect the black/White wire to the kill button on my new control will it work as a kill switch?
Thanks for any input, please feel free to correct me if I'm wrong on anything
Green. Low beam
Yellow. High beam
Black. Ground
Blue
Red
Red/yellow
If your new kill switch is a toggle switch it should work. If its a button that you push and hold, it must be normally open (I think) for it to work. In other words, it closes the circuit grounds the black/white wire when you push the button and kills the ignition. SOmeone will correct me if I have it backwards. As for the other wires, I think it tells you in the electrical FAQ.
The kill switch is like a small lever on top of the new unit I'm not sue how to tell if it's an open or closed circuit, I have read the electrical f@q and can't see what the other wires are,
I can't read the diagram too well, I've read past threads on the search section and have come accross mixed results of what the wires are and do, and what to splice them with. I would post a link to the unit I bought it off of eBay but I've only got an iPhone and I'm not sure how too.
If its a lever it will work. One way will be closed, the other way will be open. You'll just have to figure out which way is on or off. The blue wire is for the voltage regulator (goes to the silverbox mounted on grab bar) that keeps the bulbs from blowing when you rev it up. Not sure what the others are for without looking at diagram
I haven't a diagram but a list of the wires and what they do as this is a universal switch gear,
Black. Earth
Blue. Light input
Red. Rear light/pilot and instrumental bulbs
Yellow. Low beam
Green High beam
Blue/White. Ignition cut out
Pink. Horn
Brown/White. Indicator supply wire
Brown. Left indicator
Dark green. Right indicator
I was going to run:
New unit. Old wiring
Black. To. Black bikes earth
Blue and brown/White To Blue power wire from reg
Blue/White. To. Black/White on/off switch
Just wondered what the other original wires done, so I could use the bikes lighting wires instead of coming out of the new unit and add even more wires to the bike
These wires being the red and red/yellow
Thanks
I've taken apart the standard switch and have found that
Blue and red/yellow wires are on the off position
Red and green wires are on the low position
Yellow wire is on the high position
So should I run the blue and red/ yellow wires to the light input
The red and green wires to the low beam
And the yellow to the high beam
Edited by Glenyboy
Stock Banshee harness:
Yellow/Red is 12 volts into switch from regulator
Blue goes back to tail light from switch (this wire would be "hot" any time light switch is on)
Green goes out to low beam from switch
Yellow goes out to high beam from switch
