amont21987 Posted March 25, 2011 Report Posted March 25, 2011 I just put exhaust and an air filter on my bike and it fouled the plugs in a minute or two just idling and they were brand new plugs I just put in yesterday, I'm not sure why it would do that any ideas Quote
amont21987 Posted March 25, 2011 Author Report Posted March 25, 2011 Not jetting it will foul em that quick, I knew it wasn't good but I didn't think it would foul them out that fast. I kinda thought it would be jetted too lean after putting exhaust and k&n on it. I thought I would need more fuel with more air flow and exhaust Quote
MatHolland Posted March 25, 2011 Report Posted March 25, 2011 yeah it should lean it out putting that stuff on there...what does your plugs look like..sounds like a stator going bad, or maybe plug caps? Quote
amont21987 Posted March 25, 2011 Author Report Posted March 25, 2011 I'm not sure I'll look when I get home I was just assuming they were fouled because it started running like it did right before I changed them and the ones I took out were fouled. Is their anyway I can see if it is the stator besides putting a new one on and seeing if it helps Quote
MatHolland Posted March 26, 2011 Report Posted March 26, 2011 Yes with an ohm meter. Most volt meters have an ohm setting. Search google on how to test banshee stator Quote
