HardLuck Posted March 20, 2011 Report Posted March 20, 2011 (edited) Sorry for yet another carb question.... So today I went out for the first time after putting the bike back together, Bike starts up perfect and idles perfect..... Bike also runs great through all gears and powerband but only at half throttle if I give it more gas even while in powerband it starts to bog..... I'm gonna find out what jets are in the carbs "35.5mm Mikunis" But b4 that, does this sound a jetting problem or needle problem??? Thanks for any info. Edited March 20, 2011 by HardLuck Quote
Banshee Chad Posted March 20, 2011 Report Posted March 20, 2011 How is it top end, wide open throttle? Mine did that, and then when I got to the top it ran hard again. Mine was a jet, needle combo. I had the needle leaned one notch trying to compensate for the main being too big. Plus I was scared to get lean, bought this thing new... Quote
HardLuck Posted March 20, 2011 Author Report Posted March 20, 2011 It doesnt come back alive at WOT its still chuggin....I can be in 4th gear and in powerband then the second I give it past half throttle it bogs I dont have a garage so it stays at my buddies house, I'm gonna go there tomorrow and pull the carbs and see what jets are in it and where the needles are set at.... This whats done to the bike: CPI inframe drag pipes Lonestar steering stem Lonestar Carrier with polished axle Lonestar rear hubs Pro Design cool head Pro Design advanced timing plate +4.5 Lightened flywheel +6 round bar extended swingarm Tusk rear brake rotor 370 long rod K&T port and polish 35.5mm flatside carbs ported by K&T Dual Pingel petcock valve Vforce3 reeds and spacer Cascade billet intake Chrome A-arms H&S grille Trail tech headlights lots of other billet junk Skat Trak 10 paddle haulers Buffed mohawks Quote
Surfrjag Posted March 20, 2011 Report Posted March 20, 2011 sounds like a rich main jet... how does the plug look after a plug chop? Quote
MILO Posted March 20, 2011 Report Posted March 20, 2011 Yep, start with the mains and do a plug chop. Once you get the mains right, then move on to the needle and pilot circuits. Quote
Banshee Chad Posted March 21, 2011 Report Posted March 21, 2011 Definitely sounds rich. Get it figured out? Quote
HardLuck Posted March 22, 2011 Author Report Posted March 22, 2011 So tore the carbs off today , first off they were gunked up a little bit but not too bad..... the carbs are 35.5mm Mikunis by K&T. Took the main jets out and they are 320's @ half throttle it bogs really bad and even @ WOT it wont come back alive What size main jet do you guys suggest I throw in it? the elevation where I ride is 4639 ft, Little Sahara Utah. Any info will be much appreciated Here some pic's sorry there not the greatest lol from my cell phone..... Quote
HardLuck Posted March 22, 2011 Author Report Posted March 22, 2011 Okay got over to my buddies (Dont have my own garage) to tinker with my bike again... The needles are on the middle setting So it has 320 mains and needles on middle clip....... Where should I go from there??? Thanks for any help! Quote
06specialedition Posted March 23, 2011 Report Posted March 23, 2011 Those plugs look super rich IMO. Try and move the needle up one notch towards the blunt end(leaner). See how that does. Quote
HardLuck Posted March 23, 2011 Author Report Posted March 23, 2011 So leave the 320's and just mess with the needles..... Quote
Banshee Chad Posted March 23, 2011 Report Posted March 23, 2011 Idk man, mains still sound rich if its not coming alive at wot. U try giving them k&t boys a call? Quote
HardLuck Posted March 23, 2011 Author Report Posted March 23, 2011 Idk man, mains still sound rich if its not coming alive at wot. U try giving them k&t boys a call? I haven't yet, the previous owner had the motor done by them and he cant remember if it was a 4mil or 370 longrod..... Quote
