Sorry for yet another carb question....
So today I went out for the first time after putting the bike back together, Bike starts up perfect and idles perfect..... Bike also runs great through all gears and powerband but only at half throttle if I give it more gas even while in powerband it starts to bog..... I'm gonna find out what jets are in the carbs "35.5mm Mikunis" But b4 that, does this sound a jetting problem or needle problem???
Thanks for any info. :notworthy:
Edited by HardLuck
How is it top end, wide open throttle? Mine did that, and then when I got to the top it ran hard again.
Mine was a jet, needle combo. I had the needle leaned one notch trying to compensate for the main being too big. Plus I was scared to get lean, bought this thing new... ;)
It doesnt come back alive at WOT its still chuggin....I can be in 4th gear and in powerband then the second I give it past half throttle it bogs banghead
I dont have a garage so it stays at my buddies house, I'm gonna go there tomorrow and pull the carbs and see what jets are in it and where the needles are set at....
This whats done to the bike:
CPI inframe drag pipes
Lonestar steering stem
Lonestar Carrier with polished axle
Lonestar rear hubs
Pro Design cool head
Pro Design advanced timing plate +4.5
Lightened flywheel
+6 round bar extended swingarm
Tusk rear brake rotor
370 long rod
K&T port and polish
35.5mm flatside carbs ported by K&T
Dual Pingel petcock valve
Vforce3 reeds and spacer
Cascade billet intake
Chrome A-arms
H&S grille
Trail tech headlights
lots of other billet junk
Skat Trak 10 paddle haulers
Buffed mohawks
Yep, start with the mains and do a plug chop. Once you get the mains right, then move on to the needle and pilot circuits.
So tore the carbs off today , first off they were gunked up a little bit but not too bad..... the carbs are 35.5mm Mikunis by K&T. Took the main jets out and they are 320's @ half throttle it bogs really bad and even @ WOT it wont come back alive banghead What size main jet do you guys suggest I throw in it? the elevation where I ride is 4639 ft, Little Sahara Utah. Any info will be much appreciated :notworthy:
Here some pic's sorry there not the greatest lol from my cell phone.....
Okay got over to my buddies (Dont have my own garage) to tinker with my bike again... The needles are on the middle setting
So it has 320 mains and needles on middle clip....... Where should I go from there???
Thanks for any help! :notworthy:
Idk man, mains still sound rich if its not coming alive at wot.
U try giving them k&t boys a call?
I haven't yet, the previous owner had the motor done by them and he cant remember if it was a 4mil or 370 longrod..... banghead
