2-storkerHHM Posted March 7, 2011 Report Posted March 7, 2011 Okay, I have a 2004 Yamaha Banshee With t-rex cylinders, v force 3 , dynapro coil new and new wires, new CDI, w/ t6's So the only thing left I would think would be jetting or needles? I have 34 mm TM flatsides with 50 pilot and 280 mains its around 50 60 degrees pretty high humidity... Kansas... its a semi drag bike dunes or large open track bike dirt is mostly the only riding i do with it. So the problems is it sputters in high rev but mostly Wide Open Throttle in 6th... if anyone could help or give me any advice PLEASE>>> Quote
magz Posted March 8, 2011 Report Posted March 8, 2011 Okay, I have a 2004 Yamaha Banshee With t-rex cylinders, v force 3 , dynapro coil new and new wires, new CDI, w/ t6's So the only thing left I would think would be jetting or needles? I have 34 mm TM flatsides with 50 pilot and 280 mains its around 50 60 degrees pretty high humidity... Kansas... its a semi drag bike dunes or large open track bike dirt is mostly the only riding i do with it. So the problems is it sputters in high rev but mostly Wide Open Throttle in 6th... if anyone could help or give me any advice PLEASE>>> ditch the t-6's best advice you can get..... also how long are you at wot before the sputter? have you thought you could be draining your bowls? do you have a pingle? Quote
shakar Posted March 8, 2011 Report Posted March 8, 2011 whats ur elevation? u might be lean on top Quote
volcrano Posted March 9, 2011 Report Posted March 9, 2011 Okay, I have a 2004 Yamaha Banshee With t-rex cylinders, v force 3 , dynapro coil new and new wires, new CDI, w/ t6's So the only thing left I would think would be jetting or needles? I have 34 mm TM flatsides with 50 pilot and 280 mains its around 50 60 degrees pretty high humidity... Kansas... its a semi drag bike dunes or large open track bike dirt is mostly the only riding i do with it. So the problems is it sputters in high rev but mostly Wide Open Throttle in 6th... if anyone could help or give me any advice PLEASE>>> usually when ur sputtering and falling on its face like that ur too rich,what do ur plugs look like??280 seems high for mikuni flats.plug check... Quote
2-storkerHHM Posted March 9, 2011 Author Report Posted March 9, 2011 ditch the t-6's best advice you can get..... also how long are you at wot before the sputter? have you thought you could be draining your bowls? do you have a pingle? I Love the T6's tho the powerbands all or nothing ya know, I had t5s the powerbands to open... and Right at top of 6th its just starts spittin and slowy loses it power... Quote
2-storkerHHM Posted March 9, 2011 Author Report Posted March 9, 2011 (edited) whats ur elevation? u might be lean on top around 1500 ft... and the plugs there like dark brown when i pull them Edited March 9, 2011 by 2-storkerHHM Quote
volcrano Posted March 10, 2011 Report Posted March 10, 2011 around 1500 ft... and the plugs there like dark brown when i pull them dark brown.too rich.down jet mains.id bet u should be 260 in these temps.250 in summer. Quote
shakar Posted March 10, 2011 Report Posted March 10, 2011 i guess every engine is diff but i got 28mm mikuni flats on ported stock juggs with pods and close alt to u ,im at 330 main -271/2 pilot.what is your filter setup?? Quote
