I have stock a arms, and i have read places that you cannt powder coat them cause of the bushing, can you just take the ball joint out and then be able to do it? Just need some help, never tore one down and done this before so it should be interesting!!!
no.
Hey I just powdered mine. I replaced the bj boot ( WHICH IS A B***H) I had to purchase new bushings as well.
I think you may be misunderstanding what goes wrong. The bushings that the bolt goes through when you attach it to the frame melt in the oven. I had to buy new ones... its was like 30 bucks and you have to press them back in using the nut and the bolt. Its a little time consuming but it turned out fine. put a bunch of grease in the bj bootr when you replace it though because the grease burns off in the oven.
