Craig_b Posted February 10, 2011 Report Posted February 10, 2011 hey whats up, just refitting my clutch, just woundering about the clutch plates, if they have to slot in a certain way? since they have the knobly bit on the outside, wasnt sure if you put them in, in a criss-cross patter or maybe it dosnt matter ?? Quote
Jereme6655 Posted February 10, 2011 Report Posted February 10, 2011 hey whats up, just refitting my clutch, just woundering about the clutch plates, if they have to slot in a certain way? since they have the knobly bit on the outside, wasnt sure if you put them in, in a criss-cross patter or maybe it dosnt matter ?? i THINK its supposed to be offset at a 60* pattern. so like the first one goes in and the second one goes in 60* from that. The third one goes in 60* offset from second.......so on and so on. Quote
252wheelieking Posted February 10, 2011 Report Posted February 10, 2011 i THINK its supposed to be offset at a 60* pattern. so like the first one goes in and the second one goes in 60* from that. The third one goes in 60* offset from second.......so on and so on. That's correct Quote
Craig_b Posted February 10, 2011 Author Report Posted February 10, 2011 sweet cheers dudes, and are you guys throwing lock tight at the 32mm nut that holds that basket on ? Quote
shanYE west Posted February 10, 2011 Report Posted February 10, 2011 sweet cheers dudes, and are you guys throwing lock tight at the 32mm nut that holds that basket on ? no loctite.. just torque it to spec and use the lock washer Quote
4MiLLDraGSheE Posted February 10, 2011 Report Posted February 10, 2011 All is how i did it except for skme reason my builder orefers a triangle arrangment of the plates not the sixty degrees. Dunno why but i dont question him lol Quote
shanYE west Posted February 10, 2011 Report Posted February 10, 2011 really isn't a wrong way to do it.. as long as they're not lined up.. its to allow oil to reach the plates. Quote
camatv Posted February 12, 2011 Report Posted February 12, 2011 its there to make sure the plates slipp and eat your clutch up. HAHAHAHA icannot think of ANY other atv that uses the notched plates.. i use blue locktight on all internal bolts nuts etc. Quote
Craig_b Posted February 16, 2011 Author Report Posted February 16, 2011 was putting it all back together and one of the 6 pressure plate bolts snaped, god damn it 1 thing after another, going to be a bitch to try extract it from its housing, oh well it has to be done Quote
bansheesandrider Posted February 16, 2011 Report Posted February 16, 2011 was putting it all back together and one of the 6 pressure plate bolts snaped, god damn it 1 thing after another, going to be a bitch to try extract it from its housing, oh well it has to be done Were you torqueing it to INCH pounds or foot pounds, it is supposed to be inch pounds? You were using a torque wrench at the proper spec weren't you? Quote
Craig_b Posted February 16, 2011 Author Report Posted February 16, 2011 yeah it just f*cked up, took the housing off so will be taking it into work today to try extract the stud, mite be able to drill it out from the back as the holes go all the way through but will just have to make sure its dead centre so it dosnt damage the thread Quote
Craig_b Posted February 19, 2011 Author Report Posted February 19, 2011 ok so i got a clymers manual, wasnt to much of a mission, in the manual it says to torque the clutch pressure plate bolts to torque setting in "table 3" but "table 3" is weight specification, table 6 has torque specs but just has the specs for the size of the bolt, should i just torque the bolts to the 6mm spec as shown in table 6? cheers Quote
Larry's Shee Posted February 19, 2011 Report Posted February 19, 2011 Look on page 174 should be what you need. Quote
